congpay
Wifi On, But Won't Search Access Point.. Help ... :(
Hello, I have a Sprint PPC6800 already flashed with the latest stocked ROM from Sprint. I'm having a problem with the wifi. Whenever I slide the wifi button to ON, it won't automatically search for any Access points.
The 1X sign on the top bar of the display will change into somekind of a small antenna (signs that wi-fi is turned on), normally, there should be two arrows moving and pointing each other as a sign that it is searching for access points, but mine DOESN'T.....there's just that antena only....Anyone have the same problem or probably a workaround for this ? Thanks friends.....
WiFi works fine for me, haven't seen that problem. Are you sure its not something to do with your WiFi access point?
to add to this u should also recheck the wifi settings on the ppc6800 too... usally when u just get an antenna then it means the wifi is on and has a signal to connect but lacks the key or some other setting...
yap, that's what I thought....my guest is there is some registry setting that I must tinker with...I just don't know where to start ? Anyone willing to elaborate me ? Thanks....
It should work by default, so just flash your ROM after taking backup.
Could anyone with a normal WI-fi post his registry entries for : hklm\Comm\TNETW12511\Parms\ ? Thx before....
Attached
Parms.txt
