tanveer
Extract From Rom
Is it possible to extract contents of a ROM? Say for example, I like the default ringtone in Hetals ROM but I have installed another ROM on my phone, is there any other way than installing Hetal s ROM, copying the tome to storage card and then installing the other ROM?
no... u cant remove or extract from a ready preloaded rom... you could extract from the kitchen of the rom or best get the cab file for a direct install...
you can extract if you take image of rom and then dismentle it. Image is taken in bootloader mode, till WM5.
