pangodas 1 Report post Posted May 28, 2008 Hi Trying to establish a Rconnect dailup from Nokia 6088 (DKE-2 USB Cable), Downloaded the Data Suite that contains drivers for the cable and the modem Everything installed smoothly, oddly the data suite was on COM5 while the Nokia 6088 modem was COM4 (Win XP2, SP2). Tried to set up dialup connection to #777 on the modem - it gives an error 777 when dialling. Tried uninstalling Data suite and modem and just reinstalling the DKE2 and modem. Didn't work - Windows refuses to recognise the DKE2 installation unless its via data suite. Tried fooling WinXP to think it was a standard modem by just uninstalling modem and then re-installing as standard with 115200 bps etc This time I get a 628 error! The R Connect guys tell me the 6088 modem is unsupported while Nokia guys say its BS and I must have got a setting wrong. Don't think so because I've installed and used RConnect off different Nokias and different systems with similar procedures No possibility of conflict because this is a new system What am I doing wrong or is there a genuine problem with support? Modem diagnostics log below suggests there's a problem Appended below - would much appreciate a solution/ info 05-29-2008 01:10:39.203 - File: C:\WINDOWS\system32\tapisrv.dll, Version 5.1.2600 05-29-2008 01:10:39.203 - File: C:\WINDOWS\system32\unimdm.tsp, Version 5.1.2600 05-29-2008 01:10:39.218 - File: C:\WINDOWS\system32\unimdmat.dll, Version 5.1.2600 05-29-2008 01:10:39.218 - File: C:\WINDOWS\system32\uniplat.dll, Version 5.1.2600 05-29-2008 01:10:39.218 - File: C:\WINDOWS\system32\drivers\modem.sys, Version 5.1.2600 05-29-2008 01:10:39.234 - File: C:\WINDOWS\system32\modemui.dll, Version 5.1.2600 05-29-2008 01:10:39.234 - File: C:\WINDOWS\system32\mdminst.dll, Version 5.1.2600 05-29-2008 01:10:39.234 - Modem type: Nokia 6088 USB Modem 05-29-2008 01:10:39.234 - Modem inf path: oem5.inf 05-29-2008 01:10:39.234 - Modem inf section: Modem2 05-29-2008 01:10:39.234 - Matching hardware ID: usb\vid_0421&pid_0076&mi_00 05-29-2008 01:10:41.265 - 115200,8,N,1, ctsfl=0, rtsctl=1 05-29-2008 01:10:41.296 - Initializing modem. 05-29-2008 01:10:41.296 - CD is high while initializing modem. 05-29-2008 01:10:41.312 - Send: AT<cr> 05-29-2008 01:10:41.312 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.312 - Interpreted response: OK 05-29-2008 01:10:41.328 - Send: ATE0V1<cr> 05-29-2008 01:10:41.328 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.328 - Interpreted response: OK 05-29-2008 01:10:41.343 - Send: AT<cr> 05-29-2008 01:10:41.343 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.343 - Interpreted response: OK 05-29-2008 01:10:41.343 - Waiting for a call. 05-29-2008 01:10:41.359 - Send: ATS0=0<cr> 05-29-2008 01:10:41.359 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.359 - Interpreted response: OK 05-29-2008 01:10:41.359 - 115200,8,N,1, ctsfl=1, rtsctl=2 05-29-2008 01:10:41.390 - Initializing modem. 05-29-2008 01:10:41.390 - CD is high while initializing modem. 05-29-2008 01:10:41.406 - Send: AT<cr> 05-29-2008 01:10:41.406 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.406 - Interpreted response: OK 05-29-2008 01:10:41.421 - Send: ATE0V1<cr> 05-29-2008 01:10:41.421 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.421 - Interpreted response: OK 05-29-2008 01:10:41.437 - Send: AT<cr> 05-29-2008 01:10:41.437 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:41.437 - Interpreted response: OK 05-29-2008 01:10:41.437 - Dialing. 05-29-2008 01:10:41.453 - Send: ATDT####<cr> 05-29-2008 01:10:41.453 - Recv: <cr><lf>ERROR<cr><lf> 05-29-2008 01:10:41.453 - Interpreted response: Error 05-29-2008 01:10:41.453 - Hanging up the modem. 05-29-2008 01:10:41.453 - Hardware hangup by lowering DTR. 05-29-2008 01:10:41.468 - Detected CD dropped from lowering DTR 05-29-2008 01:10:42.468 - Timed out waiting for response from modem 05-29-2008 01:10:42.484 - Send: ATH E1<cr> 05-29-2008 01:10:42.484 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:42.484 - Interpreted response: OK 05-29-2008 01:10:42.484 - 115200,8,N,1, ctsfl=0, rtsctl=1 05-29-2008 01:10:42.515 - Initializing modem. 05-29-2008 01:10:42.515 - CD is high while initializing modem. 05-29-2008 01:10:42.531 - Send: AT<cr> 05-29-2008 01:10:42.531 - Recv: AT<cr> 05-29-2008 01:10:42.531 - Command Echo 05-29-2008 01:10:42.531 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:42.531 - Interpreted response: OK 05-29-2008 01:10:42.546 - Send: ATE0V1<cr> 05-29-2008 01:10:42.546 - Recv: ATE0V1<cr> 05-29-2008 01:10:42.546 - Command Echo 05-29-2008 01:10:42.546 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:42.546 - Interpreted response: OK 05-29-2008 01:10:42.562 - Send: AT<cr> 05-29-2008 01:10:42.562 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:42.562 - Interpreted response: OK 05-29-2008 01:10:42.562 - Waiting for a call. 05-29-2008 01:10:42.578 - Send: ATS0=0<cr> 05-29-2008 01:10:42.578 - Recv: <cr><lf>OK<cr><lf> 05-29-2008 01:10:42.578 - Interpreted response: OK 05-29-2008 01:10:42.578 - Session Statistics: 05-29-2008 01:10:42.578 - Reads : 34 bytes 05-29-2008 01:10:42.578 - Writes: 20 bytes ATQ0V1E0 - OK AT+GMM - +GMM: Model 199 AT+FCLASS=? - 0,2.0 AT#CLS=? - COMMAND NOT SUPPORTED AT+GCI? - COMMAND NOT SUPPORTED AT+GCI=? - COMMAND NOT SUPPORTED ATI1 - COMMAND NOT SUPPORTED ATI2 - COMMAND NOT SUPPORTED ATI3 - COMMAND NOT SUPPORTED ATI4 - COMMAND NOT SUPPORTED ATI5 - COMMAND NOT SUPPORTED ATI6 - COMMAND NOT SUPPORTED ATI7 - COMMAND NOT SUPPORTED Share this post Link to post Share on other sites
