opensource
Actual Cost Of R-connect On Fwp Plan 500
I will really appreciate it if any of you could tell me what are the actual internet usage charges on R-Connect if I use FWP with Plan 500.
Reliance website http://www.relianceinfo.com/Infocomm/html/...riff_plans.html only gives rates for Plan 1000 and doesn't even say apply same for Plan 500 or anything.
How's the rate calculated? By my duration online? Or is it charged only when the connection is active.
Your answers will be very much appreciated.
Thank you.
simplest thing to do would be to replace the Rs 1.00 with 1.10 in the white highlighted column and u'll get the rates for plan 500 :)
The rate is calculated by the duration you stay online and not by transfer.
Actual R-Connect rates for FWP:
6:30 AM - 10:30 PM => 26/- per hour
10:30 PM - 6:30 AM => 12/- per hour
That's it! :)
Okay, thanks guys ;)
  Quote
Vishal Gupta Posted on Jul 24 2004, 01:08 PM
The rates using Rs. 1.10 work out to be Rs. 28 at peak hours and Rs.12.6 at half-hours :)
By the way didn't Reliance increase the night-time pulse duration to 600 seconds from the earlier one of 360 seconds?
