sjslall
Moto Q Not Being Detected By Qpst
1. I got this Moto-Q from Ebay (cdma). Wanted to activate it on Tata Indicom Network.
2. The QPST tool will not detect the phone on any COM ports.
3. I have added 10 virtual ports using the HW Virtual Serial port tool. Followed the link for details:
http://www.mobile-files.com/forum/showthread.php?t=48711
Now when I load any of the virtual ports on QPST, nonbe of the ports detect the phone attached. I have tried this on appx 6-7 systems.
Please let me know where I am going wrong.
Can our techies help for Tata Networks too :unsure:
I wouldn't mind placing on Reliance network. Just need to get this working.
I can also courier it so that this can be looked into.
check your antivirus and firewall. Disable thats the best solution.
@Kshah - Can Antivirus or Firewall block any Serial Port of the system :o
You first have to enter Diagnostic Mode on your Moto-Q (we do it by pressing ##3424# in HTC Phones, dont know about Motorola) and then attach the USB cable. After that you have to Install Quallcom/Motorola Diagnostic Modem Drivers (search for them for Moto-Q). It will then show up as a Port in the Device Manager. Read that Port no. Only then will it be detected by QPST.
Edited by dkaile
hello sir . i have done 2 moto q successfully by that process to register on tata. if u want it to b done u can send to me . i will do fr u . thx
its a virtual serial port created by software through IP , so it can be blocked by firewall
