shadab2506
How Connect Rim Lg Rd5340 Connect To Internet
How can connect the RIM LG RD5340 connect Internet.
Pls give the complete detail.
:signthankspin:
buy data cable of ur handset and install lg modem drivers create a dial up connection manualy from control panel network connection and now in the dialog box
username -mobile number
password -mobile numer
dialing number #777 and then dial and u will be connected to internet and install adobe active x player for support of web pages
install_flash_player_active_x.exe
Does this handset support Net connect?
Does this have RUIM support?
no ruim support .. was very good handset and in demand when it was launched
1) yes support Net Connect
2) no Ruim support, but can be fixed (need to do RnD)
