Vishal Gupta
Motorola As A Cell Scanner
Hi guys
i dont know for which model this method is?
i found it on a website.
so i posting here.
hope techies can find something interesting in it.
You can make your Motorola into a cell scanner. The hardest part is grounding
the right pin. Grounding this pin will put your phone in test mode. On most
flip phones there are 3 pins visible when you remove the battery. The center
pin is visible but will not make contact with the center pin on the battery.
You must have a rechargeable Motorola battery or a battery that has an
metallic contact on the center pin of the battery. To put the phone in test
mode, take a piece of aluminum foil and role it into a strip big enough to
fit into the gap in the center pin on the phone. Make it large enough that
it protrudes above the plastic of the phone so that is makes contact with
the center pin of the battery. Make sure that it is not too small and falls
into the phone! Once you have placed the foil, turn on the phone (unlock it
if needed). Numbers are displayed 1 screen full then it quickly flashes to
the next.
CHAN \/ PWR LVL
x x x x x x <--Rx Sig Strength, 00-99
SAT -->x x x x x x x <--1=TX Audio OFF
1=TX on <-- : : : : 1=RX AUdio OFf
1=SigTone ON : : 1=Control Channel
Press the # key. The phone should display US, or something like that. Now
to scan cell phone channels you enter the following:
When you enter 11xxx# the xxx = the channel number not the frequency.
I will provide a list of frequency to channel number at the end.
353#-Select Handset audio path
08#-RX Audio ON
11xxx#-Three digit number,
e.g. 11362#
11xxx#-Change to another channel
Be very careful with the rest of the codes because some could mess up the
cell system and some could erase your phone! The codes will work with all
Motorola phones because grounding procedures differ.
01#-Restart (Turns unit off and back on)
02#-Display current radio status (non-scrolling version
of above display)
04#-Initials Unit to Standard Default Settings:
-Carrier OFF
-RF Attenuator to max power
-Receiver Audio Muted
-Transmit Audio Muted
-Signaling Tone Off
-Resetting of Watchdog Timer Enabled
-DTMF and Audio Tones off
-Audio path set to speaker
05#-TX Carrier ON
06#-TX Carrier OFF
07#-RX OFF (Mute RX audio)
08#-RX Audio ON (Unmuted)
09#-TX Audio OFF
10#-TX Audio ON
11(CH No)#-Sets to desired channel
12#-Set power to x; 0=max 7 = min
14#-10 Khz sig tone on
15#-10 Khz Sig tone off
19#-Display software version number (4 digits)
25x#-SAT Tone on when
x=0, SAT = 5970 Hz
x=1, SAT = 6000 Hz
x=2, SAT = 6030 Hz
26#-SAT Tone off
27#-Transmit Data
28#-1150 Hz Tone on
29#-1150 Hz Tone off
30#-770 Hz Tone on
31#-770 Hz Tone off
32#-Clears all timers and resets User's programmable features to standard,
also clears user stored memory.
33x#-Turn on DTMF Tone for X, X = 0-9, * or #
34#-DTMF Tone(s) off
35#-Display RSSI ("D" Series portable only)
35x#-Set Audio path to xx = 0, VSP mike (mobile only)
x = 1, speaker
x = 2, Alert
x = 3, Handset
38#-Display ESN in Hex, 2 char at a time, use * to step
(Compandor OFF (D series portable only))
39#-Compandor on (D series portable only)
41#-Enables Diversity (on f19cta series only)
42#-Disables Diversity
43#-Disable Diversity
44#-Disable Diversity
45#-Display current rssi
46#-Display cumulative call timer
47x#-Set Rx audio level, 0-7
i.e. 474# is mid level
48#-Set side tone on
49#-Side Tone off
53#-Enable Scrambler option when equipped
54#- Disable scrambler
55#-Programming customer/system information
Enter 55#, display shows U5 '
Enter 55# again, proceed as if you've followed the sheet included with the
phone. This allows one to change the phone params an infinite number of
times. However, some of the info is not in sequence with the sheet provided
with the phone.
58#-Compandor on
59#-Compandor off)
61#- Serial number transfer (for dmt/minitac only) (See Esn transfer procedure elsewhere)
62#-Turn on ringer audio path
63#-Turn off ringer audio path
70#-Abbreviated field transmitter audio deviation command
71#-Abbreviated field power adjustment command
72#-Field audio phasing commands
73#-Field power adjustment command (dmt/minitac only)
well, basically, what we are doing here is called packet scanning.
since all phones (GSM & CDMA) use a packet based communication system instead of a live line,
by saying a live line, i mean like radio, which has a specific frequency for each station, whereas in GSM & CDMA, the provider (eg Reliance) has got a specific frequency of operation like 400MHZ for example.
next, each phone gets a sideband(sort of) like 385.35Mhz and the next 385.36 MHz. but mostly a few phones use the same sideband (* a few)
and then they send packets, with headers which identify the phone to the service providers tower.
so basically what is written above, enables us to scan for other packets in a specific sideband thereby enabling us to scan other phones using the same frequency.
though from the above post, i cant figure out wheather it's for motorola GSM or motorola CDMA.
moreover, shorting different pins may DAMAGE THE PHONE BEYOND REPAIR!! so be careful before trying out such stuff.
