MVP
999 Recharge
Has anyone successfully done 999 one month unlimited easy recharge? I tried twice but both times it came out as topup instead of netconnect plan. The dealer reversed the charge both times. I went to web world today. The CC executives said they cannot assure whether the recharge will be done as netconnect plan or topup. The vouchers are not available anymore. Is there anyone in this forum doing 999 netconnect easy recharge?
Yes, Our Web World has done a lot of 999 Recharges to Unlimted Netconnect Plan, and Customers are successfully using it.
@Amit Jain
My dear friend, you must mention WEB WORLD EXPRESS or RELIANCE MOBILE STORE instead of only mentioning WEB WORLD in your posts.
As you must be knowing that WEB WORLD is only used for company owned outlets.
So, please edit your post.
Some Web Worlds and Web World Express has been given to Franchisee to run them and Some are directly Operated by Companies Own Staff.
@Amit Jain
My dear friend, we are not talking here for other outlets. But talking about the outlet in which you are employed. So please post the facts only about your outlet.
And my dear friend, you yourself mentioned in your signatures :
Reliance Mobile Store RMS (formerly RCO or WWE)
Then why you have mentioned WWE (Web World Express) here ?
So you have to mention WEB WORLD EXPRESS or RELIANCE MOBILE STORE in all your posts, not WEB WORLD.
As you didn't edited your post yourself, so I have to do it now for you.
And please remember to mention WEB WORLD EXPRESS or RELINACE MOBILE STORE only in your post from now instead of mentioning WEB WORLD.
Have already edited!
Didnt you check it?????
My dear friend, You had edited your post only when I was typing my post.
Anyways, as you had edited your post yourself, now its good for you.
@Amit Jain
My dear friend, their is no issue now, as you had edited your post. We appreciate your efforts.
And please take care by next time, not to post such things which create misconceptions among the members and lead the threads off topic. As you done in this thread :
http://www.rimweb.in/forums/index.php?showtopic=13981
We don't want to repeat the above story again. As this thread too is going off topic now.
Take care my dear friend.
Point noted. 999 is only for prepaid data cards.
Yes, 999 is meant for Prepaid Data Cards only.
One more thing, To check the status of Balance and Validity of Prepaid Data Card Vouchers.
SMS "Netbal" to 53739.
@ Honest : Dont call me again Friend, Dear Friend, I am not your friend.
@Amit Jain
By using these words you are loosing your reputation on the forum. Members here are smart enough to understand the whole thing.
I used to be friendly with everyone and not specially with you. ;) You can check all my 2800 posts and you will not find a single post which doesn't start from the words : "My dear friend".
So, its our duty to respect all members on the forum. So I did with you also.
Thanks for the info. I tried it on my prepaid mobile and thats why it didn't work.
