cman21
Where Can I Get A Ruim Card
I live in the U.S. We do not have swappable cards here for the cdma networks. I am with a company called alltel right now and they use the cdma network. I would like to purchase a ruim card and try to put my account information on the card so that i can then swap it to a phone that uses the gsm network. Any information would be helpful. Thanks Chris
Even if you are able to transfer your account information to the RUIM card, a CDMA RUIM card is not going to work with a GSM handset.
Smart cards or RUIM cards are unwritable as of now.
