Honest
Brando Sells Iphone A2dp Bt Transmitter
Brando Sells iPhone A2DP BT Transmitter
Raise your hands those of you who have issues with the iPhone not being able to support more Bluetooth features? Go on, don’t be shy. I’m sure there are more than just a few of us who are mad as heck that for one thing that neither the iPhone nor the iPhone 3G supports. Stereo Bluetooth. But that was the past. The future is Brando’s iPhone compatible Bluetooth A2DP Transmitter.
The device doesn’t require batteries as it runs on the handset’s power so no charging of any kind is required. It also supports AVRCP functionality and also has a small LED indicator. This device has been a long time coming. My biggest worry is that Apple will now expect third party manufacturers to go on making devices to make up for the iPhone’s shortcomings, instead of Apple making the adjustments themselves. I hope I’m wrong.
The Bluetooth Transmitter is priced at $62 which would be just about Rs. 2,640 and is available from Brando.
Courtesy : Tech2
