yash 0 Report post Posted August 15, 2008 hi, 1. Spice C810 has a 2000mAh battery whereas D88n has a meager 800mAh battery. I am considering buying a D88n and using a 2000mAh battery of C810 in it. Has anyone tried it before? Are the batteries interchangeable? 2. In D88n, is it possible to store SMSes in the memory card? The site claims that it can store only 370 SMS while i need to save even more. Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted August 15, 2008 hi,1. Spice C810 has a 2000mAh battery whereas D88n has a meager 800mAh battery. I am considering buying a D88n and using a 2000mAh battery of C810 in it. Has anyone tried it before? Are the batteries interchangeable? 2. In D88n, is it possible to store SMSes in the memory card? The site claims that it can store only 370 SMS while i need to save even more. My dear Both The battries are differnt in size and shape , The Battery Of C-810 Is very big in size and cannot be inserted in small back cabinet of D-88n. More over you can save the sms on ur pc with pc sync. software and also send and recieve the sms through that pc sync. in ur D-88n storage memory for sms is internal and on sim card not in external memory. Thanks And Regards, Vikas Mahajan Share this post Link to post Share on other sites
