jabir
My Htc 6800 Fell Into Water Please Help!
I had a trekking trip to a near by jungle. On the way when crossing a river i slipped on rock i and my phone fell into water with the handset in my hand. the phone just touched the surface of water. The camera key side. THen i switched off the phone . After some hours i switched on it but the buttons are not working. Then i leave it to dry for 10 hrs under a bulb. After that i gave it to a local service center just to check the water or fungus is inside on the board. they are not much specialized in the cdma phones. They said they cant see any circuit brakes or something they suggested to htc serivce center.
Now thr problem of the phone is Buttons are not working. Camera Key, Conn Manager Key,Email Key, Internet Browsing key, Voice commadn key, OK (key on side of phone), Windows Key, Ok key, Call Key (Green), End Key (Red), Left & Right Soft buttons not working. The power key and d pad working fine also sliding keyboard have no problem. SO please help me someone wht i do? now
It is now 100% board level problem, as we had already discussed. Now the thing is, if you go to HTC, they may give you estimate more than the cost of the phone. Try them first, after that you can talk to sadik, if he can get it repaired somehow in Mumbai. That will be your best bet.
Sorry for the late response. I think you could read this link and try methods suggested there. Might help, not sure. No harm in trying.
This is the link: http://www.wikihow.com/Save-a-Wet-Cell-Phone
Thanks for suggestion. But the problem is what i do now. Can I repair it self or i hav to goto service center
Today There is a strange behavior from my phone..
I told u about the non woking of buttons. Today at morning 10:15 a m my phone's some buttons are come to working condition for 5 mins. The buttons then worked is (Windows Key, call end key, Camera Key, OK Key (Side), OK key, Left & Right Soft buttons. But still Call key and comm manager key not working. After 5 mins some black magic..... all keys goes to non working condition except some keys like dpad, power buttons (I think after i reseted the phone).
Any suggeston Please help
hey, I have the same problem, water did the same thing to my Mogul. have you find any solution for the problem?
please let me know. thanks
