brwed07
Reliance Data Call
We are trying to establish Data call using AT commands between two Reliance Mobile CDMA numbers. The commad we are using is atdt'the other phone' number but we get No Carrier.
Does anyone know if Relaince has disabled this service on their network.
Any help will be appreciated.
Brewd07.
Hi brewd,
yeps ... the last even I tried it - the results were similar... StaticElectricity can throw a little more insight, try searching for him in the members - and PM him about the same.
cheers
karki
Get CDMA AT command list and try out the data access area. It should work
you will not be able conncet two devices on data call. Dont waste time. I have tried this in association with network guys. Reliance back end do not allow incoming data call. That is the reason no fax facility is available on reliance.
My attempt was to receive fax only.
