tanveer 59 Report post Posted August 14, 2004 Hi here are these links, since i am a complete geek as far as the technical aspect of gadgets are concerned, i would like u all to check them out and please tell me if all these things work for GTRAN and our model 4020 or not. also please let me know if there are any useful and beneficial things to be gained from these pages. http://www.cdma-gsm.ru/cdma/soft_gtran.htm http://www.cdma-gsm.ru/cdma/codes.htm Share this post Link to post Share on other sites
nil 0 Report post Posted August 15, 2004 Debug Mode : [0] [1] [#] [7] [2] [7] Test mode: [0] [1] [#] [7] [6] [5] ref: http://www.cdma-gsm.ru/cdma/codes.htm The debug mode gives some clock & battery status. In Test mode, u can add commands ... dont know commands yet plz try & post it. - nil Share this post Link to post Share on other sites
tanveer 59 Report post Posted August 15, 2004 are there any risks involved with trying these codes? have u tried these? Share this post Link to post Share on other sites
nil 0 Report post Posted August 15, 2004 (edited) Hi, these are the command u can give in test mode. Try at ur own risk. Before changin any value, note down the default value. dont play with things whose meaning u dont understand I have tried 37, 00, 02, 20, 21. works gr8 ... especially 37 adds blinking Service light notification. Debug Mode : [0] [1] [#] [7] [2] [7] Test mode: [0] [1] [#] [7] [6] [5] 00 Phone Restart 01 MODE change 02 LCD contrast 03 LCD VREFM 04 LCD CMS 05 LCD c-pattern 06 Lcd eor 07 Lcd rastr no 08 lcd bias 09 LCD SETUP 10 LCD BACKLIGHT 11 SUB LCD LIGHT 12 TONE SELECT 13 SUB CONTRAST 14 MIDI RX_VOL 15 VOC RX_VOL 16 VOCI TX_VOL 17 CODEC TX_GAIN 18 CODEC ST_GAIN 19 VIBRA ON/OFF 20 CALL LED RED 21 CALL LED BLUE 22 TX AGC O/P I/P VALUE 23 cdma CHANNEL 24 RUIM FAKE MODE 25 HOUR MODE 26 CAMERA reg 27 CAMERA R_VAL 28 CAMERA MODE0 29 CAMERA MODE1 30 FOLDER UP COUNT 31 EXT POW ON 32 ALL CLEAR MEMORY 33 VOICE MAIL 34 RUIM PRESENT 35 DIMMING ON/OFF 36 UFB TEMPCMP~3 37 Service Lamp 38 MINOR VER 39 BRIGHTNES CONTROL 40-44 ? 45-99 INVALID COMMAND Edited August 15, 2004 by Chirag Share this post Link to post Share on other sites
gadget_monk 0 Report post Posted August 20, 2004 25 hour mode is also good - change it to 1 for 12hr (am/pm) format instead of the 24-hour (military time) format. Share this post Link to post Share on other sites
gadget_monk 0 Report post Posted August 22, 2004 Also check out Debug Menu: [0] [1] [#] [3] [2] [4] it gives a few diag tests on the mobile phone Share this post Link to post Share on other sites
tanveer 59 Report post Posted August 27, 2004 Hi, i fidddled around with these codes and landed my self into a problem, when i switch on my phone it vibrates and pink LED lights up, also when i switch off the phone, and charge it, there is no indication of charging, i mean it does not show phone charging message.... can anyone help, amy way to reset to factory settings? Share this post Link to post Share on other sites
gadget_monk 0 Report post Posted August 28, 2004 tanveer - if you want i can paste the values that my phone displays for some of the settings you have changed. let me know a list numbers for which you want the default settings. Share this post Link to post Share on other sites
tanveer 59 Report post Posted August 29, 2004 I used the reset phone and i restored everything to factory settings. No problems for the moment , even i did not know which all codes i had tempered with. Share this post Link to post Share on other sites
setu_garg 0 Report post Posted September 4, 2004 I know what you did, tanveer. You must have changed the EXT POWER ON value from 0 to 1. Thats command number 31. I think it means how phone will react when charger is plugged in. That is why i am interested in knowing the meaning of the codes. I am still not able to find them. Share this post Link to post Share on other sites
