unbeaten
Reliance: Problem Wit Zte Mg 880 Modem
hi frnz pls help me... am using reliance netconnect card ZTE MG 880 usb modem.. when i connect to the card, am getting some signals for some time and suddenly goes to 0 kbps and remains in zero for some 5min and becomes normal... but after five or ten min it again becomes zero,,, this occurs all time.... but the signal bars are full... am using vista os.. i complained to them about this but am not getting my solution,, am using netbooster too but no use.... pls help me frnz.. i believe on u..
@Naveen
My dear friend, although your problem seems to be the Network Specific but still you can try Pinging your connection and check if the problem solved or not.
You can get the Ping method by searching the forum.
Ping it.
It goes in DORMANCY and awake.
There some tools posted on forum for pinging, search it.
dear friend your question is not clear, what is your problem. weak signal? or line geting disconnect? try http://www.internetdownloadmanager.com/?v=512b4 and downlode sume file , then check yor I/O transmision .
cheers!!!!!!
galaxy
