viper_in_blood
Plz Advice...
i hv a data card zte mc 315.....the no on tht card has expired......is it possible to take new prepaid no on it...plzz advice.... :Equivocado:
if its inactive, asking for pin, u can upload..
Method 1:
Dial *228 from The Card. Listen the IVR. If it asks for Pin no. then you can use it.
Method 2:
Send sms from any reliance phone as :
GETSTAT RSN to 53738
RSN is the RSN no. of the ZTE Card.
Best luck.
Method 1:
Method 2:
Best luck.
thnks a lot.....i will try n m do hoping tht ur method will be a sucess......
