Vishal Gupta 4 Report post Posted August 18, 2004 Guys! If u forget ur Reliance FWP (LG LSP 340E) Security lock code. Then use 6278 ( master code ) as four digit lock code. This code will definitely work whether u specified any other code as security code. user code is any xxxx on FWP, 6278 100% works to unlock. Share this post Link to post Share on other sites
kurtaboy 0 Report post Posted October 21, 2005 nope... not for the lg lsi 110 fwp... got the code for that? Share this post Link to post Share on other sites
@ksh@T 20 Report post Posted October 22, 2005 thanx for this R'n'D......i will b thankfull 2 u.....if it wd worked... Share this post Link to post Share on other sites
Sadikk 301 Report post Posted October 23, 2005 Worked for me. Thanks Vishal Share this post Link to post Share on other sites
InfoGeek 0 Report post Posted October 23, 2005 That's stupid. What's the fun of having a lock code then. Once the master lock code becomes known, anybody can use any phone. Share this post Link to post Share on other sites
iankitahuja 0 Report post Posted November 28, 2005 Oh That Really Works! Can u tell me where you came to know abt it? Share this post Link to post Share on other sites
cmahendra 9 Report post Posted December 5, 2005 (edited) Oh That Really Works! Can u tell me where you came to know abt it? 48461[/snapback] AAM KHAO BHAI, ankit! PED KYU DHOONDHTE HO? PAKAOO SAWAL! HA HA HA thanks a lot! Vishal Mahendra Edited December 5, 2005 by cmahendra Share this post Link to post Share on other sites
Ganesh 0 Report post Posted December 6, 2005 If someone forgets the lock code then one can use this Share this post Link to post Share on other sites
Hunt3r 0 Report post Posted December 9, 2005 yes, 6278 works for lsp-340... is there any code available for lsi-110 and lsp-350 ?? Share this post Link to post Share on other sites
Honest 836 Report post Posted December 10, 2005 yes vishal it works. thanks Share this post Link to post Share on other sites
shan 0 Report post Posted December 23, 2005 yes, 6278 works for lsp-340... is there any code available for lsi-110 and lsp-350 ?? This code works for that models also. Share this post Link to post Share on other sites
supernova 47 Report post Posted December 25, 2005 yes, 6278 works for lsp-340... is there any code available for lsi-110 and lsp-350 ?? This code works for that models also. no it works only for lsp 340 e ..........does anybody know for other model or lg mobile ? Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted December 27, 2005 this code also works for LG LSP 350R. I hv checked it!!!! Share this post Link to post Share on other sites
source 0 Report post Posted April 3, 2006 (edited) I forget the lock code of my phone now it's locked. I want to unlock it through software myself. what softwarei use and where do i get that please help it's urgent !! <TOPIC MERGED!> Edited April 3, 2006 by Vishal Gupta Share this post Link to post Share on other sites
amtrag 20 Report post Posted April 3, 2006 Try 6278 it's the master code for LSP 350. ...so no need to use any software! Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted April 3, 2006 Just enter this code while unlocking. no matter whatever u have set, this 6278 works Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted April 3, 2006 i used 6278, it works on my 350r very well, despite my having another lock code altogether. try it, its very easy. Share this post Link to post Share on other sites
BPP 0 Report post Posted April 3, 2006 some tell me master code for LG 2130 also Share this post Link to post Share on other sites
schumi 0 Report post Posted April 10, 2006 i used 6278, it works on my 350r very well, despite my having another lock code altogether.try it, its very easy. I tried using this code for LG LSP 350 but it doesnot work. It works only on my LG LSP 340. So does anyone know the code for LG LSP 350 and even for LG 2030 handset ? Share this post Link to post Share on other sites
amtrag 20 Report post Posted April 10, 2006 Try 6278it's the master code for LSP 350. ...so no need to use any software! Dear schumi, this code works for my LSP 350. Share this post Link to post Share on other sites
schumi 0 Report post Posted April 10, 2006 Try 6278 it's the master code for LSP 350. ...so no need to use any software! Dear schumi, this code works for my LSP 350. Its good for you if it works on your LG 350 Handset. There might be something relating the Version.Do you know the Code for LG 2030 Handset? Share this post Link to post Share on other sites
KingofKalyan 0 Report post Posted April 10, 2006 As far as i know there is no master code for LG handsets like 2030, 2130 etc etc,, Use unicdma to unlock it Share this post Link to post Share on other sites
BPP 0 Report post Posted April 10, 2006 Use unicdma to unlock it??? what is this?? Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted April 10, 2006 @schumi This code "6278" works for my LSP 350R also... @BPP For more information on UniCDMA, pls read following topic: Bitpim / Unicdma - What is it all?, Need help! Share this post Link to post Share on other sites
thinkpositive 0 Report post Posted April 11, 2006 it works on lg lsp 350 r Share this post Link to post Share on other sites
