mon 0 Report post Posted October 9, 2008 Can anyone tell me how to connect multiple Huawei Modem EC325 on a PC as i'm facing problem when connecting more than two modem at a time. Please help me out from this problem. Luv n rgrds Thxs Share this post Link to post Share on other sites
Honest 836 Report post Posted October 9, 2008 ^^^ My dear friend, thats not possible at all. You can't use multiple modems at a time. Regards. Share this post Link to post Share on other sites
mon 0 Report post Posted October 10, 2008 Sirji If its not possible how come Bonrix has posted 8 modem support with the software he is providing to send SMS through Huawei modem. Regards Share this post Link to post Share on other sites
faizone 15 Report post Posted October 10, 2008 it is possible through a concept called Internet Connection Pooling.. it is possible if the internet is through an ethernet interface... havent tried it with usb though Share this post Link to post Share on other sites
ACS 130 Report post Posted October 10, 2008 SirjiIf its not possible how come Bonrix has posted 8 modem support with the software he is providing to send SMS through Huawei modem. Regards @ Mon - plz provide link to that Bonrix thread.. Is this only for SMS's, cause if its for doubling your net speed, i doubt it. Share this post Link to post Share on other sites
mon 0 Report post Posted October 10, 2008 SirjiIf its not possible how come Bonrix has posted 8 modem support with the software he is providing to send SMS through Huawei modem. Regards @ Mon - plz provide link to that Bonrix thread.. Is this only for SMS's, cause if its for doubling your net speed, i doubt it. Bonrix software can be downloaded from www.bonrix.net Share this post Link to post Share on other sites
mon 0 Report post Posted October 10, 2008 it is possible through a concept called Internet Connection Pooling.. it is possible if the internet is through an ethernet interface... havent tried it with usb though sirji plz tell how to work out internet connection pooling any software to complete my task? Share this post Link to post Share on other sites
Arun 795 Report post Posted October 10, 2008 It is possible to use multiple modems in a PC at a time to increase the total speed, but the ISP has to support synchronization of multiple modems. Reliance does not support it, nor most of the Indian ISPs. Share this post Link to post Share on other sites
Gauravsinghal 11 Report post Posted October 11, 2008 It is possible to use multiple modems in a PC at a time to increase the total speed, but the ISP has to support synchronization of multiple modems. Reliance does not support it, nor most of the Indian ISPs. I think he is talking for increasing sms speed by connecting the multiple modems not the internet speed. But it is very easy if we connect more than one modem then all modems are connected easily . I have connected two modems simultaneously and both have been coneected easily and can be easily seen. If u have any problem then call me i am very happy to help u. Share this post Link to post Share on other sites
mon 0 Report post Posted October 12, 2008 Yes sir u got my problem but have u connected more than two modems then only the problem arises the machine getz restarts after we connect the third or the fourth modem. U just find out the problem Thxs n regards Share this post Link to post Share on other sites
xya6103 0 Report post Posted October 20, 2008 Can anyone tell me how to connect multiple Huawei Modem EC325 on a PC as i'm facing problem when connecting more than two modem at a time.Please help me out from this problem. Luv n rgrds Thxs simple just call bonrix.net on 09426045500 and discuss the problem.. regards, cdm@guru Share this post Link to post Share on other sites
