9331840148 0 Report post Posted October 14, 2008 Nokia 6275 CDMA Bluetooth MODEM Connectivity with Nokia PC Suit 7 (1) Find and download " Nokia_PC_Suite_Cleaner_7_0_1.exe " from nokia site then CLEAN all existing PC suit (if any earlier version of PC Suit 7) and any other Nokia software earlier installed in your PC for Nokia 6275 CDMA. Then restart your PC (Computer). CABLE CONNECTIVITY & PC SUIT: (2) Download PC Suit 7 from nokia site then install it in your PC. The CA-53 (CA-70 too) cable driver along with PC Suit and Connection software will now be installed in tour PC and you can use all the benefits of PC suit 7 here except the MODEM (Internet Connection) connectivity. BLUETOOTH AND MODEM CONNECTIVITY: (3) After you have successfully installed PC Suit and tested functionality of PC suit you will probably need to use the Phone MODEM to connect the internet. PC Suit 7 does not accept MODEM connection through CA-53 cable but bluetooth so you need in install bluethooth software came along with a compatible Bluetooth Adapter. (a) Install the bluetooth Adapter in your PC. ( Enable Bluetooth connection in your Nokia 6275 CDMA mobile phone © Search for a bluetooth device from the bluetooth main withdow - it will detect your mobile phone (d) Pair your Mobile with your PC through Bloetooth. (e) Now connect the inbuilt phone MODEM by selecting the appropriate option (Bluetooth Dial-up Networking) by right clicking the phone icon from the Bluetooth main withdow. (f) Your MODEM will be installed. (g) Now a dialogbox will open as you try to connect the MODEM from the bluetooth main window, - (i) Here, for Reliance Mobile users, you type your user name: (your ten digits phone number) and password: (your ten digits phone number) and the number to dial #777. Hurray! you are now connected to the internet! - Soumendra Nath Thakur Share this post Link to post Share on other sites
Honest 836 Report post Posted October 14, 2008 ^^^ My dear Soumendra, their is no need to post multiple threads on the same topic. One thread is sufficient. Regards. Share this post Link to post Share on other sites
