mobileguru 0 Report post Posted October 14, 2008 Dear Members, How can I use the RUIM with my Nokia 3105? It consists of a SIM slot. Currently it is with in-built RIM number. Regards, Kunal Share this post Link to post Share on other sites
spknair 1 Report post Posted October 15, 2008 In my knowledge it is not possible. RUIM slot is not active (hardware not supported)in RIM's NK3105. Share this post Link to post Share on other sites
thinkpositive 0 Report post Posted October 25, 2008 not possible in TATA indicom too............ tested.......... Share this post Link to post Share on other sites
prathod 3 Report post Posted October 31, 2008 You will have to flash the mobile with a uim flash and then u would be able to use ruim cards of reliance as well as tata's on your nokia 3105. For flashing the mobile u will have to take it to a mobile repairing shop and they may charge u between Rs.100 to Rs.150. Also remember that all your contacts,sms and other details on the nokia 3105 will be wiped out and lost forever so its advisable to backup your phone using pcsuite, and before going for flashing the mobile make sure that you use an hcc card to transfer the no to a ruim card or else u will have some trouble to get the active number on the handset to be transfered to a ruim. Dear Members,How can I use the RUIM with my Nokia 3105? It consists of a SIM slot. Currently it is with in-built RIM number. Regards, Kunal Share this post Link to post Share on other sites
