Rapsterdr2003
Is It Possible To Use A Ruim Chip In A Gsm Handset After Transferring Connection To It?
I wanna program my CDMA service onto a RUIM chip ... can i then put that chip into an unlocked GSM phone and use it or is there something special that i have to do? any info will be appreciated and solution will be awarded thanks
Nope, no chance of that!
Gsm and cdma are two different technologies.so you cann't do what you are thinking to do.
Petrol in a diesel engine or vice versa? don't even dream of it.
its simple both gsm cdma phones use different radios one reconises cdma programming in the chip and one recognises gsm programming on the cheap......from what i have learnt the the programming doeesnt matter what matters is the radio.....
so no gsm service with cdma radio and no cdma service with gsmradio
If u can do it
jus let us know coz then u will be our new Tata And Ambani with Mr.Mittal
