HetalDP
Converting Titan / Vogur To Meid
To start, you need:
(1) Titan/Vogue in SuperCID state
(2) QPST
(3) CDMA-Workshop
(4) SPC Code used for EPST
The steps are actually very easy.
1) Go to the Titan/Vogue. ##DATA#, or start \Windows\DMROUTER.exe -diag
2) Start QPST, and enter service programming.
3) Press "Read from phone". You will be asked for your SPC number. Enter it.
4) Close QPST.
5) Start CDMA-Workshop and in NVItem Read 1943 Item and save it to Text File
6) Edit that Text file in Reverse Ending Order to Replace New MEID
7) Write that NVItem using CDMA Workshop
icon_cool.gif Reset your phone.
Hetal bro .... how does this figure in India's perspective? We have ESNs only I presume? ALso, what would the benefits be ?
Edited by shubhanyu
wHAT IS MEID PLEASE EXPLAIN
Well the newer range of RUIM's from reliance and most from TATA authenticate their network registration based on MEID - kind of kinky and tough to break into wall.
Whats MeID?
Its the Mobile Equipmen identifier.
More details from http://en.wikipedia.org/wiki/MEID
@ Hetal :
great work bro ... that means I get the tata plan that we were talking about on my htc :D hehehe
If ESN can be changed to MEID then the reverse should also be possible.cmd if possible then touch diamond could be unlocked easily,i hope,as esn is easier to unlock.techies please shed some light.
well diamond as such uses a meid/pESN ....this method helps u to convert titan/vogie to meid ....but as far as diamond is concerned ......it has been possible to get over the CID locking......spc has been unlocked.....infact the pesn and meid hex also have been tried to change but the problme seems to b after resetting the device u r back to the same pESN .....so this simply shows that meid is at a location different than memory ....may be in nand radio.....so the search is on for the location of meid as and when it is pointed out ...it wont take much time from there...also if some one tries for reverse engineering it cud work .......but i guess there have been claims on some forums abt this so i guess v shud wait a bit for it the soln must b around the corner
