chirdeep
Suggest Me A Replacemet Of Nokia 6275 ..
Hi Folks
I presently have Nokia 6275 which has starting giving trouble now. I plan to change over to a new handset probably having similar functionalities. & capabiities.
Please suggest an alternative in sub 10k range.. I understand LG has recently launched a new CDMA handset.. any clue which is this one?
Warm Regards :sos:
My dear Chirdeep, in my opinion you should hold your purchase for sometime and try Reliance GSM after its launch.
As of now Nokia 6275 is the best handset available below the range of 10K.
Imported handsets are already under scanner of DOT. So can't recommed the same.
Just go for treo755p ...gr8 phone u can go thru threads for the same on the forum u will get an idea about it....only u won't get warranty on it....
Unfortunately nothing better than Nokia 6275 in this range.. although that too comes with avg. battery nowadays.
Better not go for Spice C 810 as mentioned all across the Forum.
Earlier i too used to reccommend C810 but tooooo many problems & many batches are unreliable.
