cabowabo
Pin Configuration Of Lg Rd 2030
maybe this will help->
  Quote
PHONE SIDE:
Pin 1 = Red (Voltage +)
Pin 9 = White (Data) <--- I dont know if is RX or TX Data
Pin 12 = Green (Data) <--- I dont know if is RX or TX Data
Pin 14 = BLack (Ground)
SERIAL DATA CABLE SIDE
Pin 1 = Green
Pin 5 = White
Pin 6 = Black
Pin 9 = Red
I think PIN configuration is required for DATA Cable.
I mean if someone wants to make a data cable for a mobile, he is required to know the PIN configuration of that mobile.
Am I Right???
Exactly for that we need to know which pin goes for data and which for other purpose..
And stuff which gives this info is wat he asked as PIN Config.
  Quote
PHONE SIDE:
Pin 1 = Green
Pin 5 = White
Pin 6 = Black
Pin 9 = Red
Guys,
I may be wrong but I clearly remember the serial port pin configuration on COM ports of PC's has pin's 2 & 3 as transmit and receive (or vice versa). In this pin configuration I don't see those pin numbers used at all. So a cable with that pin configuration on PC side should not work.
I'll try to check my cable configuration tonight and post the same.
Can anyone check this once again please ?
Regards
What is the Pin out of the port of the LD RD2030 i.e. what are the Tx , Rx pins etc.
Thanking you in Advance. :D;)
  Moderator Note said:
Your Post has been moved here. Read the topic fully and post any questions U have here
Edited by Code
