Saurav
Choice Number
What is the procedure to Change MDN for Reliance GSM Number?
I want a Number of my Choice Prpaid/ Postpaid.
If some amount 100-200 is required I will pay.
I am in Punjab Circle.
is this service previously offered by any company????
in postpaid you can have the number of your choice....but in prepaid you cannot.....!!...i think so.....if im wrong please correct
Reliance CDMA gives option to change number in Prepaid but for that u hv to pay Rs 200/-
I would suggest that u wait for some more time till u forward the request to CC. Most probably fancy numbers will be preserved for postpaid subscribers (have seen it with BSNL/Vodafone).
yes fancy numbers are reserved for postpaid as last six digits have been blocked for shifting cdma numbers to gsm if required
Change of circle is possible for now at Rs.200 but no option yet for changing number/MDN.
Now post paid is launched. is there any process now to change the number?
If any 1 looking for some choice or premium no.s
Let me know I can get u in very good price.. :Sorprendido:
I need anumber for Punjab Circle series is 9023
need 90233-XY000
X may or may not be equal to y.
what will this number cost?
Secondly, I hv learnt Reliance is alloting Postpaid numbers after activation. No SIM with prealloted numbers. Correct if I am wrong.
000 ending nos are not free . though u may get in between 000xy.
i would be interested in any 000xy gsm number for bangalore
if gsm postpaid is launched in bangalore then you can try in your nearest ww/wwe . they surelu must be able to give you 000xy
MY DEAR FRIENDS RELIANCE has got mad, I have 2 CDMA postpaids, last week i requested for mdn change at CC ,they will be charging me 250/- that is ok but themain problem is that neither they are telling me the series of mdn going on in my area and nor they are providing available MDN's for my area these foolish CC are asking me to give 3 numbers of my choice , i gave them of my choice and not more than 3 they take, now my request is rejected bcoz those numbers given by me are not available and asking me to provide 3 new choice numbers again, i asked them how can i know which numbers are available and this time again if my own choice numbers are not available then till when my lucky chance would come then they are saying SORRY SIR! but we cant provide you with numbers available then how one can get his number changed!!!
Go to webworld and check there..
You may get the list and series there
I hv given request to a channel partner hope he gets a good number for me. He asked me to wait till 31 march. Now expecting 000.
IF ANY ONE INTERESTED IN 9333333333 PLEASE CALL ME
Change of circle retaining the same number?
I mean I can migrate from Maharashtra to Tamil Nadu using same number?
Plz PM me the tentative rate..
No, number will be changed.
As per the above post by saurav, then even this number will change if bought by another Circle ?
PK Daga plz confirm.. is the offer only for Chennai-tes ?
Im asking you this for a good reason.. My relative's number ends in 99999 (platinum number)
Now he wants to only change the initial 5 digits & retain 99999.
Edited by ACS
i want a reliance GSM no same as my CDMA No. is it possible.??? if yes then hw much i have to pay. well my cdma last 6 numbers are 907700.
this should be a free number . check with nearest ww . or if paid . it should be of 2200 or 5500
Can anyone suggest some good premium number available for free.First few digits will vary like for punjab I hv 9023.
What is cost for number ending with 000786 and XXX786 or 786000?
I want it inpunjab circle 9023 or 95690
Chennai Tata Docomo Number ending with 786 will cost 5000
