Mufaddal
Nokia Local Sensor
Nokia Locate Sensor can help you find lost keys, phones, bags, purses or anything you’re likely to need right before you rush out the door. Revealed at the Consumer Electronics Show, it’s currently a project kicking around the labs at the Nokia Research Centre, but it’s an interesting one.
First, quick explanation. The sensor is a tiny device, no bigger than a small thumb. It attaches to whatever you’d like to attach it to and communicates with your phone wirelessly (though we’re not totally certain how, just yet - there’s no official release so we only know what’s been reported so far). Drop whatever has the tag attached and your phone will alert you, via a software app that sits on your phone, and help you find the object, provided you’re within 100 meters of it (probably not good for speed boat jaunts then).
The system also works the other way around, so you could have the sensor on your person, and if you get separated from your device, an alarm will sound to let you know. Support for 100 individual sensors is provided by the app and each sensor has enough power to last 18 months before it runs out of juice.
nokia-locate-sensor02-157x104.jpgnokia-locate-sensor04-157x104.jpgnokia-locate-sensor03-157x104.jpgnokia-locate-sensor06-157x104.jpg
gr8 concept
nokia invents all new concepts.. few of their models got FM transmitter too..
its not a concept ....it will go into mass production pretty soon
