ash1005
Please suggest a GSM Handset with EDGE Class 10
I want to know which is the cheapest mobile handset having class10 EDGE connectivity and what could be its price....
have a look at supernova series of nokia
7210/7310 ...comes with class 32 edge /a2dp bluetooth
u will get within 5-6k
i use Nokia 3110c
good for internet purpose.
Why 10 Class?
Go for A Class Edge with MSC 32...
You can find this in atleast model - Nokia 7210 Supernova - In 5.5k.
@ashf
My dear friend, you can try LG Dynamite Series GSM handsets. They are quite reasonably priced.
What is class 10 EDGE technology?
Will class 32 edge be useful here in India because a average throughput of 100-110kbps(MAX 236kbps) is obtained with class 10 edge handsets..Will i get more bandwidth with class 32 handset .Does it depend on network provider like airtel
though u might not get it right now, but better to be future proof as 3g should roll out by next year... but remember, Edge (EGPRS) is an extended version of GPRS whilst 3G is based on WCDMA. Totaly different technologies. Edge is refered to as 2.5G...
Edited by dkaile
I do not need 3g handset .I need handset featuring at least class10 edge.nokia 7210 supernova is class32 edge and is not a 3g handset.I think nokia 3110c is the cheapest .Any other is available?
u can go for nokia 3500 classic
but as it is i were in ur place i wud have gone with 7210 supernova as it a bit more over 3110c with more features and superb built quality
