Dj 25 Report post Posted January 19, 2009 used a sony initially till it developed a buffer under-run problem within 4 months of usage... it was replaced twice by the company till the end of the first year but eventually died in abt 12 months of me buying the first one... moved to samsung otcoedge +DL dvd burner... seemed good to work with but in the past two months, just as the one year warranty got over, it statred having a dvd burning error... it starts formatting the disk as some bookcase type and evetually fails to burn... burns cds though so pretty confusing... pls advise what do i replace this one with... need something dependable as i end up buring close to 15-20 dvds in a month easily... Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted January 19, 2009 y dont you try lite on i too had sony dvd burner but it gave up in just a few mnths Share this post Link to post Share on other sites
Honest 836 Report post Posted January 19, 2009 Considering the best DVD Burners, Sony and Samsung are really good. But LG also is anytime better. You can try LG DVD Burner. Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted January 20, 2009 My LG and BenQ are going strong since last 2 years... I am burning Divx DVD's 1-2 daily... Share this post Link to post Share on other sites
Dj 25 Report post Posted January 20, 2009 thx guys... will chk out the ones suggested here... Share this post Link to post Share on other sites
