paragpatil
Unable To Use Gps On 8330 Bb
I am unable to use GPS on 8330 on Reliance CDMA need help and assistance in how to unlock gps.
For now GPS cannot be used in Reliance
Thanks for quick response...
is there a work around same?? having a feature on phone and not being able to use it is a sad thing!!!
I am told the reliance has locked this feature by bb support team....
GPS is independent of network one is on... so GPS chip set should be able to gather data provided by sat.
Looks like unlocking the phone might do the trick (if what they are saying i.e its locked by reliance). I am on rel and intend to use rel so unlocking should not cause harm right???
Pl advice
Try flashing your phone with rom which support gps. Its really sad on cdma part that they lock even network independent features. I started hating cdma due to this reason only.
Any suggestions where do I get such ROM from?? By cracking this hardware for all networks, would that solve this?
Have u subscribed to BIS/BES?, if yes, load Google maps on to your mobile. works well. Will be solution to your gps issues. ( will work only if ur device supports GPs though. I've no idea of feature list of 8330. though it's working on my friend's 8830 we with BIS plan. <_<
try downloading device software(reliance) from BB site, go to download section, choose operator(reliance) & then d/l the s/w. this should do the trick. (make sure u subscribe ti BIS. else it won't work. :GirandoOjos:
Thanks!! I tried update from reliance bb site still the same problem!!
I have google maps on the phone already but it doesnot provide accurate info, it gives appx position in 5000 mtrs.
I have unlimited bb plan.
try zooming in. else search crackberry.com or blackberry forums for device software from the operator which supports gps. else try this link http://www.blackberrynews.com/2008/06/10/f...s-on-your-8330/
Edited by nawalsingal
Can you suggest rom that I can flash this phone with?? also it will be gr8 if I could get url to download it from...
Thanks...
I tried your suggestions even downloaded gpsed on phone. Phone just endlessly keeps looking for satellites with no result.
Can someone help me resolve this??
Thanks...
I guess I finally found a post that tells how to do it...
http://forums.crackberry.com/f134/storm-gps-fix-telus-148687
For carrying this procedure need following information:
SPC Code
PDE IP Address
PDE Port Number
Kindly help in getting following info...
8330 has GPS ??? I'm a tad bit surprised ... did not notice the chip ... had one open today afternoon with me here ... (from an american operator)
the gps shud get activated by loading a non reliance firmware ...
also few days back i had read abt enabling agps for ur blackberry on mobile-files ( provided u have bis )
where can I get non reliance firmware??
Can you provide some link??
I have BIS plan(unlimited one)
A-Gps on CDMA give location fix that is 5-10 km away, there is no sence in using this...
I Need following details:
PDE IP Address
PDE Port Number
Someone Kindly help....
Edited by paragpatil
