savramesh 37 Report post Posted February 24, 2009 Suggest me a cheap and best Linux Web hosting Provider. Server should be stable and reliable. They should give good customer support. Easy payment options. I am currently using Nettigritty. Share this post Link to post Share on other sites
Arun 795 Report post Posted February 24, 2009 Nettigritty is one of the best Indian web host. What problem are you having with them or why do you want to move away from them? All the requirements that you mentioned should be fine with them. Remember, you get what you pay for. If you go cheap, you will probably end up in an oversold server. Share this post Link to post Share on other sites
kshah 452 Report post Posted February 24, 2009 After lots of experiments and web hosts, I selected yahoo as my host in sept 2008 and I am happy with them. I tried 3 host in india and 1 in us they were directihost, then some one in kolkata, then one in ahmedabad and one in us. I am talking about total 6 years. Yahoo india gives 5 gb for 2000 only. Plus unlimited mail id. My config is yahoo as host and google as mail host. Google as mail host are better than yahoo. Share this post Link to post Share on other sites
savramesh 37 Report post Posted February 24, 2009 Nettigritty is one of the best Indian web host. What problem are you having with them or why do you want to move away from them? All the requirements that you mentioned should be fine with them. Remember, you get what you pay for. If you go cheap, you will probably end up in an oversold server. yes i agree that nettigritty is BEST. only reason for looking another provider is to reduce cost.. Share this post Link to post Share on other sites
Bablus 66 Report post Posted February 24, 2009 I use HAWKHOST... Provides a lot of features.. Share this post Link to post Share on other sites
