dhullazaran 3 Report post Posted March 10, 2009 Dear Friends, ever time i start my MOGUL, i am getting the following error:- Filesys.exe Cprog.exe and then my handset gets real slow. Please help. waiting for your reply. Share this post Link to post Share on other sites
dkaile 1,051 Report post Posted March 10, 2009 (edited) yeh sab kuch jyada ched chaad ka natija hai... and maybe overclocking also.... try removing any recently installed programs.... remove and then reinstall battery and restart few time... if that does not work, u may have to hard reset... do take pimbackup of all your data and sms before hard resetting... read this - http://msdn.microsoft.com/en-us/library/ms885423.aspx http://pdaphonehome.com/forums/samsung-sch...-cprog-exe.html Edited March 10, 2009 by dkaile Share this post Link to post Share on other sites
ssr 10 Report post Posted March 10, 2009 Dear Friends,ever time i start my MOGUL, i am getting the following error:- Filesys.exe Cprog.exe and then my handset gets real slow. Please help. waiting for your reply. did u get missing file, corrupt file or just a message box with file names? Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted March 10, 2009 now this is what happens when u do registery tweakings , use unofficial 3d drivers and other stuff ... your filesys.exe is screwed bro ..u need a hard reset When the operating system boots, NK.exe loads FileSys.exe directly from the ROM files system ...FileSys.exe then initializes the registry from the default registry in the ROM file system FileSys.exe will then read the registry entries to start various applications.... so if Filesys.exe is screwed up then your phone is screwed up ..if still the issue isnt gone then reflash rom Share this post Link to post Share on other sites
dhullazaran 3 Report post Posted March 12, 2009 your filesys.exe is screwed bro ..u need a hard reset Yes sir, i needed to do HARD RESET, now the things are fine. Share this post Link to post Share on other sites
