noblejose 0 Report post Posted March 16, 2009 hi, I am Noble Jose, from Bangalore. I am on TATA WiMax 384kbps infinity, What will be the ideal download speed? I hv checked with so many speed tests, but all of them giving different results, I don't know why? My speed test results given below, Please help me to find the correct result. http://www.amitbhawani.com/tools/bandwidth-meter - 190.40kbps http://www.speedtest.net/ - 332kbps down and 283kbps up with NY server. http://www.auditmypc.com/broadband-speed-test.asp - 165kbps down 344 up http://www.intel.com/cd/personal/computing.../eng/383655.htm - 510kbps !! http://www.broadband.co.uk/broadband-speed-test.jsp - 176Kbps down 213Kbps up. http://www.dslreports.com/speedtest?flash=1 - 173Kbps down and 306kbps up, Latency 428ms with NY And for a single file download from download.com or any other major site, is 20-22 KBps, technically I should get 46-48KB/sec on a 384kbps plan right? Should I raise a complaint to TATA about the speed? I hv checked my signal strength, and it is constant on 24-25, which is i think good enough to get a decent speed. The nearest tower is just about 30 meters from my house, no obstructions in between, should i expect better signal strength? Overall I am happy abt TATA service, because i got connection in 2 days! and no disconnect till now. I need to figure out the speed promised is correct or not. Thanks for your time Share this post Link to post Share on other sites
Arun 795 Report post Posted March 16, 2009 Speed wasn't any issue when I used TATA Indicom WiMAX in Bangalore earlier, it was just the disconnections that I had a problem with. Can you try downloading a file using a download manager like FlashGet using 10 threads/connections? Try the test file: http://www.softlayer.com/downloads/test.zip Use a download meter like DU Meter to check the speed as well. With that being said, the latency of wimax connection is always a problem than a wireline connection which will result in the speed varying. Share this post Link to post Share on other sites
