sumatrix
Problem With Nokia 6265
if u found links for rm66 then use it
bhai.it seems dead cdma handsets cannot be flashed with phoenix or diego.also when i connect my phone to phoenix ,the firmware update option doesn come up.it comes up only for gsm handsets.
Edited by sumatrix
phoenix can flash any nokia phones ...but i think it will need special hardware for cdma
u can try jaf tool
jaf tool also requires utf box for flashing ...
but i have used jaf to flash gsm phones over usb and it has worked without utf box .
u can give it a try with 6265 if it works over usb ..
if it doesnt then take it to nokia care/ local shop where they have utf box to flash it or else last option send it to me i will look into it ..
i m attaching a tutorial of how to flash cdma phones with jaftool
also u will get 6265 firmware .nfp from here
http://rapidshare.com/files/227756794/7145...5B1_5D.NFPa.exe
this is full version of jaf tool with pkey
http://rapidshare.com/files/186146404/JAF.1.98.62.rar
try it or else take it to some place where they have all these equipments ( utf/tornado box or fbus) to do a flash
VIDEO_MANUAL_HOW_TO_FLASH_CDMA_WITH_JAF.rar
thanks for the upload.i installed it,but it says box driver not installed and lets me into the software.but the problem is that the dct4 option is disabled and bb5 is enabled. when i click on the option "flash" it says flash server not found . wat to do now?
finally it worked.but dono how.here's the log
Detected P-KEY: 9000D391
P-key nokia module version 01.02
Init usb communication...
Searching for phone...Found
Reading SW version...HL190V0600.nep
Reading battery value...3900 mV
Init usb flashing...
Reading flashid... Error getting flash id...
Reading...
Phone Type: RM-66
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_HL190V0700_6265_02.NFP
PPM Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_HL190V0700_6265_02.N
if u observe the last line,it says error getting flash id.but when i restarted the phone,lol it was working.
but i dint follow the video tutorial.i instead selected the BB5 option.
and selected the nep file after clecking on the MCU and PPM option under BB5.
i also had the factory settings selected under service settings.
u get rid of box driver not found ..u need to use pkey ..
put pkey in same directory as jaf...
but all is well that ends well
though 6265 is not a bb5 phone but luckily it worked for u ....
hope ur problem is solved now
yup the phone's workin fine but the mark on the screen hasn disappeared yet.wat to do for that?is there some prob wid the screen?
looks like ur firmware old version is HL190v0600 and new version is HL190V0700.. can u confirm the new version ? also do u find any new features in the software ?
the version that showed while flashin was v0700 but as i said before i never actually flashed it since i was gettin an error.so the old firmware remains as it is..
@sumatrix
what mark are u talking abt on screen ????
i think one or more pixel is dead in his display...
