chintan1 6 Report post Posted April 21, 2009 (edited) Hi All , Kindly help me selecting a new handset . My budget is 12k & requirement is - 1} Good Internet Browser ....with java enabled support . 2} Multimedia phone . 3} Dual Sim will also do .....(optional ).. I have tried Treo ...but it lacks browser , HTC Mogul & Touch are out of my budget as of now . If i get BB 8130/8830 from Sadikk can i browse thru internet & surf the net ...i don't want BB services . How about Samsung 309/569 .. ?? Any Motorola Phones available in this category ..??? rest i don't know which handsets are available in market with this features . If u know other brands with this features please do let me know . I am bit confused . Thanks a lot for guidance in Advance . Edited April 22, 2009 by chintan1 Share this post Link to post Share on other sites
situ1962 21 Report post Posted April 21, 2009 I don't know much.but i think mogul will be the ideal phone according to your requirements.but your budget is 12k.so if you like go for a used one.some members have offered to sell theirs'.search the buy sell section and you may get what you want.hope this helps. Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted April 22, 2009 @chintan mogul is the best option available rite ow ... as suggested by situ u can go for a used mogul or touch ... if budget is ur problem then u can even ask praween ...recently he sent a brand new mogul to rimweb member for 12.5k . or else for ur requirements u stated even bb 8830 is a good option u can use gsm and cdma connections and use gprs from ur gsm connection to browse . though still u cant use relmobileowrld on it . the price at which sadikk is selling it is worth a buy !! Share this post Link to post Share on other sites
chintan1 6 Report post Posted April 22, 2009 (edited) Thanks Muffdalji & Situ for prompt Reply , I have one more doubt with BB8130 also i wont be able to surf the net . ?? Any other Handsets avaible in Market With Good Internet Browser ..Pls suggest .... Edited April 22, 2009 by chintan1 Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted April 22, 2009 I have one more doubt with BB8130 also i wont be able to surf the net . ?? not yet . no other handset will give u as good internet browsing as mogul . nokia handsets in cdma are s40 and have ok browsers if u ok with opera mini than go for nokia handsets or spice handsets or still if u want u can go for ppc 6700 ...though outdated but still u can get good browsing out of it Share this post Link to post Share on other sites
