kshah
Request To Post Evdodata Card Prl And Other Parameter
Can any one please PM me PRL or reliance EVDO card along with channels? There is no harm posting here too. Choice is yours. I want to try to make procedures where RIMwebian can check EVDO coverage so that before investing in modem they can check if EVDO is available in areas they are living / usage.
Is there any way to get it without SPC? I couldn't find the SPC till now.
In bsnl ZTE cdma workshop worked very well. I don't know about huewei model. You may try scanning memory and find.
Well mine is ZTE as well. In CDMA Workshop, what values should I try for the Memory Scan (Start, End Addr and Step)
Always Try EFS Method and read files 002 and 0002 then only try Memory Scan Method.
I have the ZTE MY 39 evdo card provided by BSNL. Is there any way to enable 1x mode using CDMA workshop or any other software? Currently only evdo mode is enabled in my card. So it doesn't work in areas where there is only 1x coverage.
Cdma workshop do not read nokia. You need nokia diego for it.
yeah ...diego is "cdma workshop" for nokia phones
