pravinuttam
Reliance Lg Rd3000 Issue
Looks like the firmware got corrupted. Go to the service center and have your firmware flashed.
Had the same problem, with RD 3000 15 days ago, it happened on that particular day about 6 to 7 times, I then switched off my cell and switched it on again, I havent had any problems after that, I think you wait for a day or 2, before taking it to the service centre, as Arun has mentioned
Edited by CUPIDON
Yes umesh bhai same thing happened in wife's mobile.
most of the 3000 set got this problem
i have lg 3000 data cable....
is that possible to flash the firmware using that???
even i want to know that..if yes then plz give full details how to do that
Hi to every one,
I had a same problem with my mobile, but it is not software problem,
my battery was not getting connected with mobile -ve and +ve leads,
i have done a desi solution for this problem, just put a piece of paper between battery and panel on topside of battery.
my problem solved ! :Contento:
good tip dear .. :)
