realdel 0 Report post Posted May 13, 2009 i purchased blackberry 8330 from reliance..i can not receive any ringtone or a picuture from my nokia mobile bluetooth...than i call custmr care they told me that i only recievd ringtone or pics only from blackberry to blackberry they shocked me is there anybdy to help me out from this redicouls prblm is there any software for this so help me out on this.... Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted May 14, 2009 first pair your nokia phone and blackberry Manage Connections -> Bluetooth Options -> Add Device.... Select your device from the list of available Bluetooth devices and enter passkey and pair it . also make sure ur phone is set to discoverable Manage Connections -> Bluetooth Options -> Press the menu key and select Options... ..Change the Discoverable setting to Yes now the most important part When you want to receive a bluetooth file do the following: 1. Go to Media. 2. Hit the menu key (left of trackball) and select Explore. 3. Browse to the folder you want to store the file in. 5. Hit Menu key again and select "receive using bluetooth." 6.You should see a message on the phone that says Waiting for Connection. 7. Send from your nokia . You'll have to do this for each file individually. you can also have a look at this video Share this post Link to post Share on other sites
realdel 0 Report post Posted May 14, 2009 first pair your nokia phone and blackberry Manage Connections -> Bluetooth Options -> Add Device.... Select your device from the list of available Bluetooth devices and enter passkey and pair it . also make sure ur phone is set to discoverable Manage Connections -> Bluetooth Options -> Press the menu key and select Options... ..Change the Discoverable setting to Yes now the most important part When you want to receive a bluetooth file do the following: 1. Go to Media. 2. Hit the menu key (left of trackball) and select Explore. 3. Browse to the folder you want to store the file in. 5. Hit Menu key again and select "receive using bluetooth." 6.You should see a message on the phone that says Waiting for Connection. 7. Send from your nokia . You'll have to do this for each file individually. you can also have a look at this video u r great MUFADDAL KM thanx for ur reply.....now help me out one more time i need sms software where i can send one msg to one person atleast 20 / 30 times or more at once ....and also if u have good software plz let us know.... thanx once again. Share this post Link to post Share on other sites
