me_saket
Mtnl Comes With Free Incoming While Roaming
mtnl anounce that roaming is available on cdma garuda mobile. Now subscriber of garuda mobile in these two cities can roam to each other city. and tariff will be re1/3min for calls made to local mtnl network(gsm+cdma+landline) of visited city. all other local and std calls will be charged at Rs1.5/min. and incoming calls will be free
thats good.
but MTNLGaruda uses landline type numbering (8 digit preceeded by STD code - same as initital R-CDMA). so how roaming is going to work, are they supposed to allot temporary local no.s.
  commonman said:
thats good.
govt has given permission to allow roaming to mtnl and bsnl cdma service.soon cdma service will have 10digit no starting with 9. so initially they wont follow cheating procedure as done by rcom. Mtnl will contiue to use same 8digit number. and not allocating any local number. rcom was given license for only WLL and rcom was following illegal way of call forwarding to avail roaming service.
good info saket..any info on bsnl full fledged launch of cdma
even i would like to know the status of bsnl cdma mobile services..
Roaming Facility between Delhi and Mumbai for Garuda Postpaid
mobile customers (w.e.f 8-6-09)
Roaming between Mumbai and Delhi for Garuda Postpaid Mobile will be available from 8-6-09 onwards. The features of this facility are as under.
1. This feature will be introduced with effect from 8-6-09.
2. The Roaming facility will be available by default for Garuda Postpaid Mobile customers only.
3. All Garuda Postpaid Mobile handsets will be programmed over the air(OTA) by default. However if any customer faces problem (especially Plan B customers) he may please be asked to contact *228 for assistance.
4. The Roaming facility between Mumbai and Delhi is free of charge.
5. Those customers who do not have the STD facility can dial only local calls while roaming. In case the customer wishes to dial national /Mumbai other operator numbers has to avail National dialing facility (STD). This can be done from any CSC as per the normal procedure.
6. A Delhi based subscriber when he is in roaming in Mumbai will be charged as per tariff of “One India Plan” given below: -
Type of Call Pulse (Seconds) Call Charges (Rs.)
Local MTNL own network 180 1.00
Local other network 60 1.00
Delhi MTNL Network 180 1.00
Delhi Other Network 60 1.00
STD 60 1.00
ISD 60 As per One India Plan
SMS Charges
Local (Mumbai and Delhi MTNL n/w) 0.40
Local other n/w and National 0.80
7. A Mumbai based subscriber when he is in roaming in Delhi will be charged as per tariff of “One India Plan” given below
NCR (0-50) BSNL Network 180 1.00
NCR (0-50) Others Network 60 1.00
Mumbai MTNL Network 180 1.00
Mumbai Other Network 60 1.00
STD 60 1.00
SMS Charges
Local 0.50
National 1.00
International 2.50
8. Roaming calls will be rated separately and debited to the customer via debit notes. No separate bills or indication in the present bill for the roaming calls. However any customer wishes to have details of Roaming calls, the same will be provided by e-mail.
9. Incoming calls while roaming between Mumbai and Delhi will not be charged.
10. No Free Call Allowance/Discount will be applicable for Roaming Calls.
Source : http://mtnlmumbai.in/willservices/garuda_roaming.doc
Dear savramesh i found one sign that shows bsl will soon come with cdma mobile of 10 digit number and that too with roaming
http://bsnl.in/service/wll_post_paid_limited_mobility.htm
Plz refer point "K"
under heading Local Call and Intra upto 50 kms
u will find Fixed to Cellular/CDMA (10 digit number) Own
That is sign that bsnl will also come with 10digit cdma soon
