coolkushi 0 Report post Posted June 9, 2009 Hello Rimwebians.. Is it possible that we can connect a GSM line to EPBAX. I have a GSM connection which i want to connect to EPBAX, so that i can use the same number over intercom. Is there some kind of Terminal available for this or any EPBAX which can also take GSM SIM card as an input line?? If anybody has any idea on this please share the information... Share this post Link to post Share on other sites
kshah 452 Report post Posted June 9, 2009 There are GSM FWT available in market. It can connect to EPABX. Share this post Link to post Share on other sites
Honest 836 Report post Posted June 9, 2009 Vodafone provides such kind of service through which you can route your calls through EPABX. Just call Vodafone CC and get further information. Share this post Link to post Share on other sites
pasumark 51 Report post Posted June 10, 2009 Even Airtel has Share this post Link to post Share on other sites
ursmv 13 Report post Posted July 3, 2009 Dear Friend, You can contact the service provider and if your usage is good are you have good no of connections they will provide it to you at a reasonable price or some times even free as company owned equipment if not you can buy it in open market it will cost you between Rs.7000 to 10000 app depending on the model. Share this post Link to post Share on other sites
