ankurmps94 0 Report post Posted June 27, 2009 First of all, Welcome to RIMWEB.in Now, Follow The steps which are stated below:- 1).If You Have Your Mobile's Pc suite,,Make a dial up connection with the following details: APN:rcomwap Number:*99# Connection Name:Reliance And Make the connection.. 2).If You Do not have The Pc Suite Than Open Control Panel-->Open "Network Connection"-->Create a new connection-->Select "next"--> Choose "Connect To Internet"-->Select "Set Up My connection Manually"-->Select "Connect Using a dial Up modem"-->select the "COM Port No" in which your.mobile is connected to-->Type "RELIANCE" in ISP name-->Type *99# In the Phone Number-->Keep blank In username and password.Click Next and Then FINISH.. 3)Now, Subscribe anyone of the plans of Reliance Gprs.. 4).After,Subscribing Connect to the connection which you have created namely "RELIANCE". 5).Open Internet Explorer-->Tools-->Internet Options...-->Connections Tab-->Choose the connection created namely "RELIANCE"-->Settings--> Do Not Choose "Automatically detect settings", Select "use automatic configuration script" Type In the Address:"10.239.221.05"-->in the proxy server box check the first option and Type Address:"10.239.221.05" And Port:"8080"--> Click On "OK" Than "OK".. 6.) Now Type http://rimweb.in VOILAA!!! you are now connected to internet and surf as much as you want!!!! BUT you will be charged for that....I am working on free access to internet You Can also Access Rworld Homepage i.e. http//:wap.rworld.co.in from IE also... Have a nice and Internetful Day!! Reply, If You Are getting any Type Of problem.. Share this post Link to post Share on other sites
me_saket 73 Report post Posted June 27, 2009 good work? But what's speed? Dear member plz don't share this idea with rcom guys otherwise, this will be stopped by then Share this post Link to post Share on other sites
ankurmps94 0 Report post Posted June 27, 2009 good work?But what's speed? Dear member plz don't share this idea with rcom guys otherwise, this will be stopped by then the speed is much better than Idea, Airtel and Vodafone Gprs and this is not a trick but a change in proxies which leads to the opening of Webpages On PC!! Share this post Link to post Share on other sites
rbdhoot 11 Report post Posted October 14, 2009 What are the charges for this ??? Share this post Link to post Share on other sites
Aijaz 0 Report post Posted October 14, 2009 Will it work on CDMA? Share this post Link to post Share on other sites
M.S.Rao 64 Report post Posted October 14, 2009 (edited) Can you please post here details of this Gprs plans Edited October 14, 2009 by nlr2334481 Share this post Link to post Share on other sites
