manishashar
Few Problems, Listed All Togather
I am using Mogul from last 6 months. A few months back I had to hard-reset the handset. After which a few issues were observed. Since they were not show stoppers, I ignored them. However listing it here for some solution
1. While typing SMS, predicted text does not appear. Before hard-boot there was option in to enable / disable predicted text but the setting is not seen after formatting the handset
2. Internet Sharing option is available but have not been able to connect it to my PC to user Internet on the PC. I use cable connector and follow steps are generally required
3. After a call is completed, if the screen had gone blank due to time specified for battery saving, I have to press disconnect button multiple times to get the screen back and to terminate the call or press ON button to get the screen back which also takes a long time. Result, if the call was actually completed at 1:55 minutes duration, the call gets terminated sometime at 2:03 minutes
4. While in a call, at times I am able to pickup the call on the Call wait by selecting "Answer" but at time it does not.
5. Could not switch between original call and call taken on call wait
6. Do not know how to conference on this handset
Lastly
7. MSN Live was installed which synd all contacts of Live in contact list, need to remove them all in one shot, is it possible ?
Thanking in advance.....
Manish
Though even I am not a genius about mogul, but don't wanna disappoint you by making this thread go unanswered.
1- I guess its present by default
2- This link should help you
3-No idea why this problem is
4/5- Guess its something related with previous problem (4)
6- Even I didn't try ever.. (Let me know if u come to know about it)
7- Didn't get you
