kshah
Nokia Care Suite, May Be Replacement For Diego And Phoenix
1.3.6 2009.13.0 of Nokia Care Suite is available. This multi-protocol service software
supports Nokia CDMA products and limited functions of GSM and WCDMA products.
Please note that this release should be considered a beta release for GSM/WCDMA models
This release should only be posted in NOL for all CDMA markets and India.
Service SW installation packages and Technical Bulletins are available from NOL.
CHANGES & ERROR CORRECTIONS FROM PREVIOUS VERSION 1.3.5 2008.42.5
• Multi flashing tools have been enabled for CDMA (GSM also, but it doesn′t work)
• Connection can be added without restarting Care Suite
• Improvements enabling Fuse application to close properly
• Finish - button available after recovery is finished
• Improvements enabling PST application to close properly
• Plugins are displayed correctly
• Improvements to product log writing
• Nokia Care Suite icon is visible on the desktop
• Error shown when a product without supported is connected
• Improvements to “Number of storing days” field for Product Log
• Error occures when product log location is set to non existing location
• Self test reporting only activated for RH-111
KNOWN ERRORS & LIMITATIONS
• Error message appears Setiings Editor when user wants to open settings file
• CDMA multi provisioning can not program PRL, ERI, Contacts and MDN information
• CDMA Settings editor not compatible with N8208 / RM-384 and N2608 / RM-376
• Fatal Error occurs when closing Product Support Tool in Vista
• Message 'fatal error during installation' may be shown
• Error during uninstallation may be shown
• Fuse Problems with N1202 / RH-111 detecting
• Fuse Confirmation dialog during changing connection's name does not work properly
• Multi Refurbish/Automatc start in Multi Refurbish process doesn't work properly when user
connects new product
• UI elements and WinVista do not work properly
• Scroll bar in Fuse doesn't change its position when user drag and drop it
• Internal Module Error during N96 / RM-247 refurbish
• Downloading software update package fails during multi refurbish
• Fuse: An error occurs while attempting to close the dialog
• Software Update/ Error messages appear during DCT-4 update process
• Application Launcher is not closed after downloading NCS update package.
Download
:previous:
thanks.. i saw this soft @ nokia care 2 weeks back and was searching for it..
it can never replace pheonix
ore jaftool .
Downloading... will update...
any updates??.
i installed it and tried 'Update phone software' under 'Product support tool for store' for my nokia 6265 using usb cable, it says 'No Phones connected'.
but Fuse shows USB1 - RM66..
