parrotred
Palm 755p Problem With Buttons Mapping
I am having palm 755p of late i am facing problem with buttons on the phone.
When i press
phone button it functions like the (up arrow)
calendar button it function like (down arrow)
menu button on bottom right near alt it functions like (right arrow)
left arrow button it functions like power button
side single button it reduces volume
bottom button reduces volume
top button switches back to the last software
when i press center button it functions like message
The phone autmoatically sleeps off and when i try to awake it with the phone, calendar, message and power button it does not activate the phone. Instead i either remove the battery or eject or insert the memory card to activate the phone. Although the phone is on.
I have hard reset this phone also.
Please help this is a strange problem.
Edited by parrotred
Were you using any third part applications that may have changed the button functioning, like agendus etc. That usually causes such problems.
Read these 2 posts and try the solutions. One alos lets you download an application btnfix which is said to solve such problems.... But the first one to erase all files and restore your data would be better...
http://forums.palm.com/palm/board/message?board.id=hardware&message.id=45886
http://forum.treonauts.com/palm-smartphones/treo-680/3080-weird-problem-phone-button-launches-calendar.html
I have tried button fix but of no help
I am really being under tension i really liked the phone but now i dont know what will happen?
I have got it repaired. The keypad was broken.
Thanks for your support.
