dineshvjoshi
Difference Between Htc Mogul And Touch Pro Cdma
I would like to know which one of Mogul pr touch pro is better .
I have heard that Touch pro many calls are rejected as the reject button gets pressed in pocket.
Does touch pro has dedicated camera button as mogul.
Does touch pro has voice activated commands
Is there separate wifi switch on touch pro as in mogul
definately touch pro is better .
it has more ram, faster cpu, os optimistaions , 3d hardware, and gorgeous vga screen
who said , accidental button press can happen with any phone .keep it in pouch
no.
yes
no, but u can have wifi toggle switch on ur screen!
also htc touch pro and diamond are almost similar except that
touch pro has memory expansion whereas diamond has 4gb fixed
touch pro has qwerty
touch pro has 512mb rom and diamond has 256 mb so u get 80mb phone memory in diamond and around 300mb phone memory in touch pro
rest all is same
so if u dont use qwerty and u need a more compact and light phone go for diamond .
i guess mogul is lighter n thinner then touch pro
touch pro is more compact and a bit lighter than mogul
I am also planning to sell my Mogula nd take the Touch Pro.
I feel PRO is more useful for me..because i need keyboard more often...
I am in the same dilemma as Hari .. we both got our Moguls same time last year .... but I am now thinking, is it not wiser to wait for our pro and bro to bring TP 2?
there is no guarantee that touch po 2 will be cracked soon , these meid based handsets are tough nuts to crack
rather go for touch pro which can work on reliance fully with data .
I am sure you will help us do it.
And what about TATA compatibility ?
see tata just needs spc and prl , but there are problems with *228 activation on these handsets , which require u to change connection to prepaid to get ur phone activated .
plux dont think it will be cheaper , it will take atleast 7 8 mnths after its launch for the prices to come dpwn
the reason touch pro is available for cheap is coz its been more than 9mnths since its release and also lot of new phones have released so prices have come down
moreoever sprint will be releasing android phone in 1 2 mnths , mostly htc hero on their networks
So you imply that it may be wiser to go with Android? :confuse:
