Irfu 0 Report post Posted August 3, 2009 Dear friends, I am using a Nokia N82 phone. While using internet the contents (text) is not displaying in the browser.so that I cannot brows throgh the websites, instead its showing some lines in the place of texts.I think I have changed some settings by mistake.can u guys tell me wat might b the problem? Please help!!!!! Share this post Link to post Share on other sites
Arun 795 Report post Posted August 3, 2009 Browser > Options > Settings > Page What all are the settings that you have configured there? 1 Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted August 3, 2009 try to go to google.com if u see lines or boxes in place of text , then most probably the problem si with fonts have u installed any fonts or changed fonts on ur n82 ?? if yes then revert back to original fonts 2 Share this post Link to post Share on other sites
Irfu 0 Report post Posted August 4, 2009 Browser > Options > Settings > Page What all are the settings that you have configured there? Dear Arun Thank for the response... These are my browser settngs Load content> All Screen size> Full screen Default encoding>Automatic Block pop-ups> Yes Automatic reload> On Font size> Large Share this post Link to post Share on other sites
Irfu 0 Report post Posted August 4, 2009 (edited) try to go to google.com if u see lines or boxes in place of text , then most probably the problem si with fonts have u installed any fonts or changed fonts on ur n82 ?? if yes then revert back to original fonts Yeah..that is the exact problem am facing right now.it shows lines only But i dont think i installed any fonts. Hw can i revert it back if so? Edited August 4, 2009 by Irfu Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted August 4, 2009 ^^^ have u installed any application which has non english fonts like arabic or something have u installed any application recently ?? Share this post Link to post Share on other sites
Irfu 0 Report post Posted August 5, 2009 ^^^ have u installed any application which has non english fonts like arabic or something have u installed any application recently ?? Ya I think had tried to install Arabic fonts.How to be uninstall this? Share this post Link to post Share on other sites
Mufaddal 678 Report post Posted August 5, 2009 if u had installed an application quran then it installs arabic fonts just install xplore and see in e:/ and in c:/ there will be fonts files ( 4files ) if its in memory card , simply remove the card , the phone will then utilise fonts in c:/ and then delete fonts from memory card or use font router Share this post Link to post Share on other sites
