CUPIDON
Problem In Nokia 5310 Gsm Handset
I have a problem in Nokia 5310, the handset hangs, after some time it works properly for saome time before hanging again, what could be the problem, can anybody help please
  On 8/12/2009 at 7:10 AM, CUPIDON said:
I have a problem in Nokia 5310, the handset hangs :Confuso: , after some time it works properly for saome time before hanging again, :Confuso: what could be the problem, can anybody help please
Buddy does it work properly between two hangs :NO::previous::SI: , i suggest get it flashed take it to Service station as they can only find out why.....
people at service centre are idiots
what they will do is tell u that u have a virus on ur phone
they will hard reset and then upgrade the firmware , thats what they do 90% of times
better u can try out few things
hard reset ur phone and memory card
upgrade ur firmware
if problem still not resolved then take it to nokia service centre and tell them to replace it for ya
