arpan.k2
Samsung Cdma Guru Muzic
Hi
I have bought a samsung cdma sch-b519 Guru Muzic phone, but it is not supporting image files in jpeg format.
Can anyone plz tell me which format is supported???
  On 8/24/2009 at 9:16 AM, arpan.k2 said:
.png format also not working
reduce the resolution and try
Just try .png or .bmp image with 128*128/128*160/160*160 resolution...128*128 is the suitable among those resolution.....download images from net & lower its resolution with adobe photoshop...
  On 8/18/2009 at 6:19 AM, arpan.k2 said:
Hi
Dear ARPAN can u give feedback of this phone hows its battery backup and all i am also planing to buy the same
Plz dont buy this handset as there are lot of problems developed after one month.
Hi
Could you please elaborate on the problems faced by you while using this phoen for the benefit of fellow members as well as potential buyers?
Thaks in advance!!!!!!!!!!
Edited by vvinayakpai
I too have this handset. battery life is very poor, hardly lasts for a day.
But, built-in speaker is very good...loud and clear. So its good for listening to music- living up to its name.
GUI is not very user friendly. I say this after using LGs and Nokias.
You may buy it if you need a good music phone within 3K budget and don't mind charging the battery every night.
1. wrong display of "Missed Calls status show " even after three times softer updation done at Samsung Service Ctr.
2. Poor battery back up (even the batter has been replaced) .
I think samsung has mentioned 4 hrs talk time.
