Mufaddal 678 Report post Posted August 27, 2009 I have seen some people having problems running hardspl on their touch pros ( greens , dkalie and counting ) now hardspl is an imp step for running custom roms and for superciding ( u know what that is used for ) when running hardspl.exe it fails to update , it can be due to variuos reasons like 1) microsoft net framework not updated to version 3.5 on ur pc 2)if u running vista 3) or for any xyz reason first try to put ur phone manually in bootloader mode , by pressing power , volume down and soft reset button , then connect to ur desktop and run hardspl.exe if still probelm persists then follow this trick Manually update ur SPL using ur sd card 1) First format card in FAT32 2) if u wanna supercid , then u will need hardspl0.25mfg 3) copy the hardspl 0.25 mfg file ( it will be RAPHIMG.nbh) to root of ur sd card 4) download the sspl manual package and unzip sspl.exe to ur phone memory on ur device 5) now using file explorer go to sspl.exe on ur touch pro and run it 6) it will pick up ur RAPHIMG.nbh from sd card and flash a new hard spl on ur phone 7) to check ur hardspl go to bootloader screen , on top it will show CMONEX 0.25spl 8) DONE now just take off ur battery and reboot note : if for some reason u r stuck at bootloader screen and cant get out of it , simply flash any rom on ur touch pro thru RUU now once 0.25spl is loaded u can supercid after supercid u need to load 0.37 hardspl to do so just load the "RAPHIMG.nbh" from hardspl0.37 folder to root of ur sd card and put ur phone in bootloader done HARDSPL 0.25.rar HARDSPL 0.37.rar SSPLManual_Raphael.zip 1 Share this post Link to post Share on other sites
