tejkumar
Need Specific Gsm Number
I am having a TATA cdma number and wanted the shift to Reliance GSM. My current number ends with 767523.
Is there any way to get Reliance GSM number (pre-paid or postpaid) which ends with same 6 digits?
Any quick help will be appreciated
^^^ I think you can try to get postpaid number if its not already taken.
just visit your nearest reliance outlet . i think you will surely get it as this is not some special ending ...
thanks for your replies..
I went to one reliance outlet but they promised only last 4 digits and not 6 digits.. :NOTriste:
Any other clues?
Can a postpaid connection be converted to prepaid after 3/6 months?
-Tej
yes ... 6 months for sure .. ib b/w 3-6 they do with great difficulty though as per trai norms i think they cant stop you from getting it converted to prepaid
:previous:
AFAIK, there is no rule to prevent the conversion of a postpaid number to prepaid even within 1 month. If I am not wrong, pkdaga converted his Tata Docomo premium postpaid number to prepaid within a month. I may be wrong.
Edited by KumaarShah
i also feel this is reliance its own policy not to do prepaid in 6 months.
if somebidy will compain to trai they will do
Any other clues?
-Tej
Call me with your specific requirement, i shall try and help you.
I also need simmilar number like my current,me 2 want to shift frm tata cdma to reliance gsm as itz postpaid option will help me to save alot while I am on roaming!!!!
I need 00696 as my last two digits,I have two connections which ends with 00696 only!!!
Can anyone guide me what is best way to get it.
Any other clues?
-Tej
Edited by enjoylifewithsms
