aviator
Help - Network Problem In Palm 755p
Guys,
M using palm 755P with tata.
from the past few days, i am experiencing the problem of network with it.
Phone becomes out of coverage all of a sudden.
Sometimes, the signals are full, sometimes they are fully gone.
It happens frequently.
Spoke to tata guys, they sent an engineer and everything was found ok at the site(my home/office)
I have an usha lexus that works fine at the same place.
I thought of buying signal booster but m nt sure whether it helps r not? Anyone has experience wid that?
Can someone tell me wat needs to be done in this case??? Is it a hardware problem? If yes, what should i do?
  On 9/19/2009 at 12:31 PM, aviator said:
Guys,
I am using 755p with Reliance and for the past 9 months i have the same issue. When the signal drops, the phone looses coverage and even when the signal strength regains, the phone doesn't respond as like other normal reliance phones. i think it is having some software issues that i couldn't get thru with it all these times.
this is the problem with most palm phones
No such problem in my palm's... upgrade to latest OS 1.07 or 1.08 and update to reliance international prl... all procedures given in treo 755 topic in my signature...
This is a problem with my 755p as well. In trains especially, when the signal is fluctuating, the phone doesn't seem to hold up the range good. And it is updated to latest PRL as well as 1.08 OS. Guess we have to live with it.
I agree, we have to live with it. I also feel sometimes that other reliance phones perform better than my Palm.
most of people including myself have experienced this problem
I am planning to jump out of palm due to this problem. Apart from this, the phone some times freezes and you have to do a soft reset.
I can give a plus to battery, voice clarity and sturdyness (broke my touch screen only after 1 year of good usage).
anyone tried signal booster which is available on e-bay
i think there is a way to fix this network problem issue with palm phones
if we cud get a way to completely flash the radio 2 3 times it shud solve it
i think the normal updates we doing isnt fully flashing the radio
i m saying this coz there was a very similar issue with palm pre which was resolved by flashing radio/os multiple times
Thanks for info...
But is there any easier way...
U knw hw tuf it ws to program it for tata.
Man, it was so tuf... Don't want to touch the programming part...M scared!!
